[Download] [Install & use] [Tutorial] [Documentation] [Release notes] [SVN access] [Server]
New Alignment API 4.2. Get it!
Alignment API and Alignment Server
The Alignment API is an API and implementation for expressing and sharing ontology alignments.
Using ontologies is the priviledged way to achieve interoperability among heterogeneous systems within the Semantic web. However, as the ontologies underlying two systems are not necessarily compatible, they may in turn need to be reconcilied. Ontology reconciliation requires most of the time to find the correspondences between entities (e.g., classes, objects, properties) occuring in the ontologies. We call a set of such correspondences an alignment. We have designed a format for expressing alignments in a uniform way. The goal of this format is to be able to share on the web the available alignments. The format is expressed in RDF, so it is freely extensible.
The Alignment API itself is a Java description of tools for accessing the common format. It defines five main interfaces (OntologyNetworks, Alignment, Cell, Relation and Evaluator) and proposes the following services:
Here is the Alignment API and implementation homepage. It is hosted by gforge.inria.fr which helps the developement process (by integrating theses pages within the SVN repository for instance).
If you use this software and want to give it credit, please cite:
Jérôme David, Jérôme Euzenat, François Scharffe, Cássia Trojahn dos Santos, The Alignment API 4.0, Semantic web journal 2(1):3-10, 2011
Please note: The Alignment API is... an API (this may be unfortunate, but it has been named appropriately). Hence, it is not a matcher. A few examples of trivial matchers are provided with the Alignment API which will indeed match ontologies. Taking such examples, which can be programmed in a couple of hours, as real matchers and comparing this with other matchers is meaningless (only when these matchers are worse than that, this is a meaningful result). Moreover, mentionning that these systems have been compared with "The Alignment API" without qualification is not appropriate. So please, compare your systems with serious competitors (hint: those which publish papers telling that their systems are good matchers; you cannot find such a paper about the Alignment API or one of its sample matcher).
Main resources
Download page and Release notes
Official releases.
Install & use
Quick start with the API.
Alignment Server
Installing a server that will generate and store alignments
Tutorial
Walk through the Alignment API features
Documentation
Supposed to be a reference manual, but not fully complete.
Technical documentations
Web service interface for the Alignment server
REST and SOAP specification of the web service interface
Wrapping ontology APIs
The package contains an ontology API wrapper called ontowrap allowing for using the Alignment API with various ontology APIs (JENA, OWL API 1.0, 3.0, soon SKOS).
Alignment format and the Expressive and Declarative Ontology Alignment Language (EDOAL)
How to express alignments that the API can input or output.
Wordnet extension
How to use wordnet within the API
Registered annotations
List of extension labels that are declared (and should not be used by others)
Eval
Using the API for evaluating alignments.
Additional resources
Bug and feature trackers
Notify your bugs and request features here
SVN access
You can browse and you can join.
Included libraries and dependencies
Wonderful components that the Alignement API and server use.
License
Basically, open source (LGPL).
Credits
When it is due.
Systems using the API
Because we are proud to be used.
Plug-ins
NeOn Alignment plug-in
Alignment API and server plug-in for the NeOn toolkit.
External resources
OAEI
The Ontology Alignment Evaluation Initiative: Benchmarks for evaluating ontology matchers and benchmarking campaigns (since 2004).
ontologymatching.org
The central resource for ontology matching and alignment information.
http://alignapi.gforge.inria.fr
$Id: index.html 1623 2011-07-17 18:20:45Z euzenat $
